Zama carb parts?
Bob DeCortin created the topic: Zama carb parts?
Looking for info on rebuilding a Zama C1U. the air purge is not purging,push the bulb in and it stays in.
I think there is a ( maybe capillary) check valve in the block the bulb sits on under a welch plug that is clogged.
Anyone got info on this thing? Got two carbs now that ended up getting replaced because of this
#25030
tootalltechie replied the topic: Zama carb parts?
Bob have you checked the zama website? Zama C!U carbs
Gordon
#25038
Gulf Coast replied the topic: Zama carb parts?
Post a pic of your carb. There should also be #'s on it's side. I fix weedeaters for a living. I can prolly help with your carb problem.
#25092
Bob DeCortin replied the topic: Zama carb parts?
I need a source for part and if the kits include the parts needed to replace the check valve for the air purge.
#25126
Still need to know what you have to help you? Zama .. Rotary...Stens... Stihl bought Zama so there quality should improve.
#25136
I need to know where to get parts.As stated above its a Zama
#25230
As stated above... Rotary.. Stens... I can send you a kit.... Can't do much without knowing what you have??? O ya Google it!
#25235
Its a Zama carburetor, the kits don't have the parts I need.
I'll never buy another piece of equipment with a Zama on it.
You can get anything you want for a Walbro. When one of these things has a check valve problem you end up buying a new carb. :angry:
#25236
You can switch the carb to a Walbro.. Just a thought.
#25240
I might have to do something like that. I might make the parts I need.
The bottom line is the crap in the gas is causing these problems. I'm going to build a separator to get the alky out and see if that helps.
Thanks for the offer
#25241
Time to create page: 0.309 seconds
