Prop Question
HarleyLou created the topic: Prop Question
Hi guys, can any one tell me what ABC Prop is close to a 6719/3.
Thanks
Luis
#24989
marc replied the topic: Prop Question
I've never really seen a ABC with a profile like the 6719/3. They do make a 2718/3 that is close in diameter and pitch, but definitely not the same rake or blade profile. They might have some new ones out that I'm not aware of though.
#24990
randyrap replied the topic: Prop Question
No such animal. Stick with the 6719/3 or 2716/2 for your Backlash. :)
IMPBA # 14315 CD
www.nlmbc.org
#24991
HarleyLou replied the topic: Prop Question
Randy, 2716/2, 15 or 20? I already have the 6719/3 554, don't want to bend and beat on it, Buddy of mine has been doing Props for many years (Ron) but mostly for Nitro's, just want one to bend and test with.
Thanks
Luis
#24992
Ron who? Jefferson? Ask him who use to do his nitro props back in the day. lol.
2716 - 20 works best. Find a 6719/3 654.
IMPBA # 14315 CD
www.nlmbc.org
#24993
Yes Jefferson,lol small world!
Thanks
Luis
#24994
Hot Rods replied the topic: Prop Question
Hi again Luis. I realize the prop you want is for a hydro/rigger, but I have a 6719/3 654 from Brent ( PWW ) that I tried on my 25 mono. But the diameter is only around 63mm. It was OK, but the motor just screamed and didn't have the topend of my other props. But I also have a 2716/2 20 degree with tips pitched up. With the larger diameter and around 6" pitch, it gives a great balance of acceleration and blistering topend. I think you could do a lot with this prop. Because it already has the rake, you would not lose blade area having to back cut. It lends itself well to rounded tips, Barr cutting, additional pitch, and diameter reduction if any of that was needed. The same could be said for the 15, if your transom needs more lift.
Just my experience with those 2 props.
#24995
Thanks Dennis, I have the 15* & 20* already, test test!
Luis
#24996
marc replied the topic: Re:Prop Question
Luis,
I just went through my stuff and found one I would sell if you want it. Not sure what the numbers are but it's a 6719/3 that was done up for my old Seaducer hydro. I'm pretty sure it's actually the prop Jerry Crowther had done for the the boat. Anyway, it was badass on the Seaducer! It has some small dings but still ran fine. See pics. If you want it, I will sell for $45 shipped.
It's the prop on the right in the pics. On the left is a 6719/3 554 PWW for comparison.
#24997
