1048 carb help!
Jorge199 created the topic: 1048 carb help!
Hello boater, recently i buy a cat with 30.5 engine and 1048 carb.... Which one is the correct needle ajustment for that carb! I will appreciate your help!!!! :dry:
#23742
slipry replied the topic: 1048 carb help!
high is 1 and low is 1 3/8 .
#23745
The following user(s) said Thank You: Jorge199
danielplace1962 replied the topic: 1048 carb help!
The LOW is between 1 3/8 - 1 5/8 turns out
The HIGH is between 1 1/8 - 1 1/4 turns out
This is the range we find that works in South Florida heat and humidity. They most often finish tuning at 1 3/8 Low and 1 1/8 High
#23746
riverrat417 replied the topic: 1048 carb help!
Good post Dan.
#23755
Canadian Hot Rod RC Boats replied the topic: 1048 carb help!
Daniel
Does the 'pop off' spring/pressue need trimming on the 1048 - ?
#23765
Jorge199 replied the topic: 1048 carb help!
Hey Daniel, Here in puerto rico our temperature normally is in 90 and humidity level is very high. So, what do you recomend me? More Reach or more leaner in those neadle ajustments
#23767
The spring pressure does not need adjustment to run perfectly.
Most of the 1048's I have are modified and run considerably better than stock.
The carbs when tuned for maximum performance do not run lean even at sustained 19,500 rpm. The plug color is some of the best I have seen.
I always tune on the rich side. Many will lean a engine out till it slows down then come back a hair. I do similar except I find maximum performance on the lean side just to know where that is then I richen it up till it slows down then back in a hair.
Just saying I like a engine tuned just a little on the fat side.
#23769
The following user(s) said Thank You: Canadian Hot Rod RC Boats, LucW AKA Loco, Jorge199
