Help setting up hardware
Canadian Hot Rod RC Boats replied the topic: Help setting up hardware
HOR is not been known for fast shipping lately but Vince at GAS rc sells and stocks that drive with a backing plate to mount tube
gasrcproducts.moonfruit.com/
#23063
gabe3366 replied the topic: Help setting up hardware
Randy how far does the 5.5" whobbies shaft fit into the HOR stinger? Also how far does the cable fit into the shaft? I'm trying to measure how long of a cable I should order.
#23067
deleted
#23068
as a note: I see by your PM where you live
These guys here are close to you and are a pretty good bunch of guys & gals (well you do have to watch Randy Rap :woohoo: - ha ha)
Maybe talk with these bunch and see if you can catch a race or two ......
www.nlmbc.org/
Cheers ......... eh
#23069
randyrap replied the topic: Re:Help setting up hardware
Ya ..... Anyone named Randy is trouble. Lol
IMPBA # 14315 CD
www.nlmbc.org
#23071
My parts came in from HOR. I was wondering how stinger length affects hull attitude. What length do you guys recommend for my hull? (115mm-130mm). I still need to order the double square end cable and prop shaft.
#23280
Hot Rods replied the topic: Help setting up hardware
I think you meant cm., not mm. A 120 cm. boat would be about 47". 4" from transom to prop is very common and works well.
#23281
The following user(s) said Thank You: slipry
deleted
#23282
gabe3366 replied the topic: Re:Re: Help setting up hardware
My bad I should have been more clear, stinger is adjustable from 110-150 mm, hull is 48".
Thanks
Btw mine appears to go down to 4"
#23283
deleted
#23284
