Help setting up hardware
gabe3366 created the topic: Help setting up hardware
No eBay APP ID défined in Kunena configurationI'm getting ready to order the hardware for my 48" wildthing mono and I'm not entirely sure what I need. I am using a weed eater with a square end flex shaft. I understand that I need to somehow attach a round end of the flex shaft to a ferrule + prop shaft. What I don't understand is how and if a ferrule can be used with a stinger drive. Does the ferrule fit into the stinger or does it go on the inside of the boat like in my diagram.
Could someone confirm if these parts are compatible:
Stinger:
Prop shaft:
whobbies.com/product.php?id=373
Ferrule:
whobbies.com/product.php?id=600
Thanks
#23033
Canadian Hot Rod RC Boats replied the topic: Help setting up hardware
deleted
#23034
deleted
#23035
tootalltechie replied the topic: Help setting up hardware
The WHH system that Randy is talking about is the SPDIII. I have that system in my boat love it no lost props unless you loose the prop nut. The one down fall is the bushings in the "cartage" don't get lubricant from the flex shaft.
#23036
gabe3366 replied the topic: Help setting up hardware
So if I were to use the stinger like the one I linked I would need a square end cable with a stub shaft pre-soldered, made to the length I need.
something like this:
aeromarinerc.myshopify.com/col...-hardened-stubs
#23040
deleted
#23041
Ahh right, I didn't realize that.
I found out that zippkits makes a stinger that fits a ferrule inside so I'll most likely just order from them.
Thanks for all the help.
#23042
deleted
#23043
gabe3366 replied the topic: Re:Help setting up hardware
Hey, if I wanted to use the HOR stinger+ shaft where could I buy a flexcable with two square ends?
Sent from my GT-S7560M using Tapatalk
#23061
Canadian Hot Rod RC Boats replied the topic: Re:Help setting up hardware
deleted
#23062
Time to create page: 0.154 seconds
