Drive dog with Prop shaft keeper grove?
triplef created the topic: Drive dog with Prop shaft keeper grove?
Does anyone know of any who makes a drive dog about .75" long with two or four set screws and a .38" grove in the center. I could build a small aluminum bracket off the back of the prop strut that could catch the prop shaft if the cable weld broke.
I would think you would put a set screw in opposite sides of the drive dog to balance the shaft?
I would also think you may be better to make a single piece rather that two separate?
Open for suggestions.
#22816
danielplace1962 replied the topic: Drive dog with Prop shaft keeper grove?
Having the drivedog extended that far beyond the bushing would put quite a bit more load on it.
.75" + .250" drive dog clearance would have the prop a ways behind the support of the bearing.
Most are running welded stub cables that do not run a stationary drivedog against thrust washers so it would need a good 3/8" movement front to rear to be sure it didn't contact the retaining bracket.
Great idea and I saw a guy do almost exactly what you describe.
An oversized shaft with a deep groove and a retainer stud protruding into the groove is common way some have used.
#22817
strictlybusiness1 replied the topic: Drive dog with Prop shaft keeper grove?
I am reading on other sites about continuing cable breakage problems, the resulting loss of the propeller shaft & the propeller. Is there a designed system that eliminates this problem, no matter where the cable breaks?
The first photo shows a complete cable, propeller shaft, bushing, drive dog & lock nut. A soldered in place, brass sleeve (.250" ID X .2812" OD X 1.500" long), which reinforces the flex cable propeller shaft joint CANNOT PASS THROUGH the machined bushing (.250" ID X .375" OD X 1.375" long) in the event of cable breakage occurring at any point from the sleeve to the engine collet. The brass sleeve rotates freely inside the already existing stuffing tube (.2812" ID X .3125" OD X whatever length). The propeller shaft bushing is a slip fit into the strut & is held in place with a 3-48 screw. The bushing is precision machined from B-10 grade Bearium Bearing Bronze. It is unaffected by the propeller's radial load & the propeller shaft's RPM, therefore it lasts indefinitely
Another part of this system, which eliminates repeated removal of the cable to facilitate lubricating the cable, is the grease fitting & Teflon sealed rubber boot at the upper end of the double walled stuffing tube. A small grease gun & Lubriplate Special Marine Grease #2 gives a very low drag lubricating system. A small amount of grease is pumped into the stuffing tube before each run, making removal of the cable un-necessary, since the grease always moves down the stuffing tube, towards the strut!
Jim Allen
Attachment 625borebarrelcarburetoronQD106.jpg not found
Attachment 625borebarrelcarburetoronQD104.jpg not found
Attachment 625borebarrelcarburetoronQD103.jpg not found
Attachment 625borebarrelcarburetoronQD105.jpg not found
Attachment 625borebarrelcarburetoronQD107.jpg not found
#22819
