AC R42
rcboats created the topic: AC R42
Hi one and all, I have just started on my R 42 and so far so good :cheer: .
I have installed the rudder , strut , water inlet through the transom , quad exhaust , pair of auto drainage outlets 3 aluminium blue right angel inlets (2 for water 1 for fuel) - :cheer: .
I have also made a start on the radio box :cheer: .
I also have a motor mounts / brackets.
All i need to save up for is a motor , radio gear and a tune pipe 2'' band not sure whether to get a aluminium , stainless steel or a steel tuned pipe - any suggestions?.
By the time i have got all that i cant wait until i can get this boat in the water :woohoo: .
I have been taking some pictures as i will down load them when the boat is finished :laugh: .
#22812
Steve Seebold replied the topic: AC R42
"A PICTURE IS WORTH A THOUSAND WORDS"
#22813
danielplace1962 replied the topic: AC R42
Looking forward to the pictures, also. Always like to check out new builds. New idea's.
Hope you don't mind. Not trying to hi jack. Something to check out till yours are posted.
First run.
If your wondering what the camera guy was talking about burning.
I had 3/4" heater hose on the exhaust so I could run it while I waited on the silicone I now have on the exhaust extension.
Pictures of the one I just built.
#22818
rcboats replied the topic: AC R42
HI there, One very nice R42 -- Your exhorst set up is different to most i have seen how do you find it? :) .
What size motor have you put in your boat? :cheer: .
The only difference in your boat and mine ( Hull ) is that i have put 2 x 40 - 50 mm (wide) X 42 (long) stripes of carbon fibre stickers on the top/sides of the Hull :) .
Q what size / type of prop/s are you using ?. :)
#22821
#22822
Canadian Hot Rod RC Boats replied the topic: AC R42
HARDCORE :evil:
"THE TALK & THE WALK " with Video >>>>>> well done
RD
#22823
Time to create page: 0.152 seconds
