pull starter
gixxer6 created the topic: pull starter
hi everyone any idea if u can one of these zippkits.com/~zippkits/index.p...products_id=425
Sent from my GT-I9100 using Tapatalk
#22598
Steve Seebold replied the topic: pull starter
Yes you can. I use then on my Zenoahs and my Quickdraws.
#22599
gixxer6 replied the topic: Re:pull starter
hi where can i get one
#22600
Steve Seebold replied the topic: Re:pull starter
I get mine from Russ Stark at This email address is being protected from spambots. You need JavaScript enabled to view it.. His price is a little higher than ZippKits, but he has them in stock.
#22602
danielplace1962 replied the topic: pull starter
Russ is selling Genuine Zenoah not the inexpensive Chinese starter.
The Chinese ones require you to open up most mounts considerably. I prefer that method and do a similar mod to the mount and pawl nut even when I install a Zenoah EZ starter. Don't like it unless the starter is bolted on the mount with no spacers.
I open my mounts for the Zenoah and mill the snout off the pawl nut so the pullstart doesn't have to use a spacer. Much better installation.
#22611
hi do u completly remove all of the snout off the pawl nut
#22659
allso can anyone tell me what thread the pawl nut hase
#22660
#22661
You use a arbor in the front side and machine the snout off in a lathe.
The thread is 8mm diameter X 1.0 pitch
#22672
thanks
#22673
Time to create page: 0.581 seconds
