I need a flywheel
Steve Seebold created the topic: I need a flywheel
I have a 20cc Zenoah and it needs a flywheel. Does anyone have an idea where I can get one?
I want to put it in a 45 sized nitro boat. I think it will either be a real kick, or it will just be in the way.
#22553
lohring replied the topic: I need a flywheel
Isn't the taper and thread on the front of the crankshaft the same as a 260? If so, any Zenoah accessories should fit. At one time Quickdraw made a brass flywheel/start pulley for the Zenoah crankshaft. They no longer list it, but may have one available.
#22556
Steve Seebold replied the topic: I need a flywheel
I wish it was that simple. There's an aluminum disk on the output side of the engine that has a magnet in it for the electronic ignition.
#22565
Canadian Hot Rod RC Boats replied the topic: I need a flywheel
delete
#22566
The following user(s) said Thank You: Boats
danielplace1962 replied the topic: I need a flywheel
If you need more weight machine a brass ring and bolt it to the aluminum one that is already on there.
Or machine the entire thing from brass.
#22610
I would love to be able to do that, but I don't own a lathe and I don't have access to one.
#22613
SRI Motorsports replied the topic: I need a flywheel
I'm sure if you made a simple drawing any machine shop in your are can carry out the work you need.
Peter Somers
SRI Motorsports
Lazer 40 LSG27 + LSG36 SAW
#22614
Steve I don't get why u need a flywheel for this engine ? Are you converting it from EI ?
:P
#22625
A good friend who used to build my racing engines has the same angine and told me it doesn't run right without a little extra weight from a flywheel.
I was just going by what I have been told.
I'm going to put it in a 45 sized Cal Craft from Lenny Blake to run it in. I think it will be a lot of fun.
#22628
Steve, the last I heard you had a CNC mill. You should be able to machine a pretty accurate circle with that. I liked the suggestion about bolting a brass disk onto the existing flywheel. Balance the assembly and you're ready to go.
PS The B Cal Craft is one of my favorite boats. I converted an A size to electric and it never handled as well as the nitro version. I think it was the extra weight. Watch that with a gas conversion. Ask Lenny, he may know.
#22633
