iv bag
gixxer6 created the topic: iv bag
hi everyone can any tell me if iv bag can be resealed with a bag heat sealer like the ones used for food bags
#22407
CC Racing Engines replied the topic: iv bag
Hello,
I have often wondered the same thing. It is one of those things I would like to try, but if it does not work the results would not be worth the trouble it could cause. If you are trying to make a smaller bag there are ones as small as 100ml.
Carlo
www.rcbwc.com
Ego Means Nothing
Talent Means Something
Heart Means Everything
Don't believe what you hear
Believe what you see.
Carlo Catalanotto
www.ccracingengines.com
1-504-304-5077
#22408
marc replied the topic: iv bag
I have used some in the past that had been resealed with a bag sealer...they did work fine for me. I didn't make them though was a friend that made them.
As Carlo said though, there are many different sizes available out there and usually they fit better than modified bags.
For example, my friend had made 250ml bags by shortening larger bags. Well a 250ml factory bag is narrower and fits better in most cases than a shorted wider 500 or 1000ml bag. I guess one could modify the width too though. Bottom line I would use factory made bags as much as possible and use custom if absolutely necessary. Also, a good bag sealer would be required...the material is pretty thick.
#22410
