struts- skeg verses no skeg
bn2o created the topic: struts- skeg verses no skeg
I've searched and searched and can not find the info on this. My question is about using 2 skeg struts on a 60 inch cat with twin powerplants verses using 2 normal round bottom struts.
#22039
CC Racing Engines replied the topic: struts- skeg verses no skeg
bn2o,
I can only give you information from personal experience. Everytime I have ever tried to run a cat without a skegged strut I have had trouble with the boat through the corners. If you are looking for just all out straight line speed and not really concerned with how the boat turns at speed then no skeg will be a good choice for you. If you would like it to be stable through the corners without the back end of the boat sliding out with the cost of a little top end speed then struts with skegs will be a good choice for you.
Carlo
www.rcbwc.com
Ego Means Nothing
Talent Means Something
Heart Means Everything
Don't believe what you hear
Believe what you see.
Carlo Catalanotto
www.ccracingengines.com
1-504-304-5077
#22048
The following user(s) said Thank You: bn2o
strictlybusiness1 replied the topic: struts- skeg verses no skeg
If the strut, the propeller shaft housing & the skeg, were three individual pieces made of steel, silver soldered together, the strut & the skeg could be very thin. Since the skeg is a short piece it could probably be as thin as .0625" (1/16") at it's widest point. If it was machined as a wedge from front to back there would be minimal drag even if it was 1.500" below the shaft's housing. The three pieces are keyed together, therefore no fixture or jig is required to silver solder the pieces together.
The steering struts Ed & I built had .0625" thick X 1.250" wide X 1.500" deep skegs. I don't remember if we tested different depth skegs. Struts were .1250" (1/8") thick with lightening holes.
Jim Allen
#22049
bn2o replied the topic: struts- skeg verses no skeg
Carlos and Jim, I want to say thank you very much gentleman. My main concern is making this boat turn, I believe I will have enough power to run well down the straights and pull it through the turns IF I can make it turn. Again gentleman thank you!!
#22114
Hugh replied the topic: struts- skeg verses no skeg
You can always sharpen the manufactured hardware and put a fine glass bead on it to reduce drag.
#22120
Sorry Carlo for calling you Carlos.
#22291
No problem that is very common. LOL
www.rcbwc.com
Ego Means Nothing
Carlo Catalanotto
1-504-304-5077
#22313
