water cooled exhaust flange
gixxer6 created the topic: water cooled exhaust flange
hi can any one help me withthe two o'ring positions on water cooled exhaust flange :unsure: :unsure: :unsure:
#20624
Canadian Hot Rod RC Boats replied the topic: water cooled exhaust flange
Most are - put o ring on header - install header into flange ring - may need bit oil - then put second o ring between header (after u get into flange ring - and tighten
should be - flange ring - oring - header - o ring - flange to motor - gasket - motor
#20627
The following user(s) said Thank You: gixxer6
