Best Hybrid motor?
MATHO created the topic: Best Hybrid motor?
Guys,
if you have all parts of the known ChungYang (Sikk), RCMK and ZENOAH motors on your workbench and if you are not able to machine anything (you cab assemble and disassemble only), which hybrid (combination) would provide best power?
For example:
RCMK S254Evo lower end combined with ZENOAH 28.5cc top set.
#20447
Mercury94 replied the topic: Re: Best Hybrid motor?
RCMK bottom and Zenoah elecrical and cylinder(small or large bore) makes a tough little engine IMO.
#20448
Canadian Hot Rod RC Boats replied the topic: Re: Best Hybrid motor?
gee no "bee house parts" :laugh:
I'd use
MK SX case
Sikk + 2mm Crank
MK K30 piston
MK K30 RZ cylinder turned side ways
Zen ignition and EZ start (I'm old)
Sikk 771 carb
#20449
MATHO replied the topic: Re: Best Hybrid motor?
Randy, I am talking about mass production........
#20450
Yes Thomas I seen that :laugh: ... I did create one using all production parts --
OK
MK S254 case
MK +1mm Crank
MK K30 piston
MK RZ cylinder - turned sideways
771 carb
#20451
Scott replied the topic: Re: Best Hybrid motor?
You GO Randy ....
#20452
helen3 replied the topic: Re: Best Hybrid motor?
I am sharing some links.Hopefully you get more information.you can find help from the folwing link
www.ijcee.org/papers/466-N20019.pdf
web.mit.edu/newsoffice/2011/hy...solar-1021.html
regards
helen
Nitrotek
#20465
