Warpath Rigger?
rmankilla created the topic: Warpath Rigger?
Hi Guys,
I just got a use Warpath rigger and have a question on what kind of turn fin are you guys using on this rigger? Should I cut the rudder and how far is the rudder be from behind the boat? Thank!
#20261
marc replied the topic: Warpath Rigger?
Use the Warpath fins! :) Rudder leading edge should be 1-1/8" from transom. Strut should be Speedmaster extended round bottom on 2" brackets. You want the back of the strut at about 3.5" from transom whatever strut you use.
www.modelgasboats.com
Home of the WARPATH Riggers
#20268
ANIMAL96 replied the topic: Re: Warpath Rigger?
CAN I GET THE PART # FOR THE STRUT AND RUDDER TO USE ON MY WARPATH, AND WHAT IN LB SERVO TO BE USED. THANKS ALLEN
#20269
marc replied the topic: Re: Warpath Rigger?
Allen,
I have updated the build manual with the P/Ns. Here is a link to the manual: www.modelgasboats.com/images/s...s_R20121004.pdf
Strut: Speedmaster P/N: SPDS-010-250MR 1/4" Strut XTD assembly (strut brackets should be 2” long)
Rudder: Speedmaster P/N: SPDR-013-1SB or the SPDR-011-60SB, 60/90 Rudder
Assembly. Both of these seem to work equally well on the boat. The first is a straight blade, the second is a tapered blade.
I use Hitech 755MG 1/4 scale servos on steering. Anything with around 200oz of torque should be fine.
Hope this helps.
#20270
