good sorce for 1/8 laun plywood
baotman created the topic: good sorce for 1/8 laun plywood
Hi new guy here
Im in need of a good sorce to buy 1/8 inch luan plywood . Does anybody have a good sorce they get there wood from, would appreciate any help thanks baotman
#20221
ridgerunner replied the topic: Re: good sorce for 1/8 laun plywood
If you're looking for laun plywood,a building supply place sometimes has damaged interior doors and sells them cheap.I got some birch doors locally for $3 a door with some beautiful grain and color.If you're looking for aircraft grade birch, Aircraft Spruce www.aircraftspruce.com and National Balsa www.nationalbalsa.com are good places.Aircraft grade is the better of the two with it's glue being waterproof but laun can be used if sealed inside and outside really good.The laun doesn't like harsh bending and will split if bent too far.
#20224
