Conquest problem
SHOOTING created the topic: Conquest problem
hello i have build Aeromarines Conquest, the engine WH M5 w/tune, the problem the boat goes always to right ! the prop is Prather 275 , i try to move the strut lower and higher same result , i have shim the right side of strut , only small diference .
Sorry my english is not verry good
Can you help me ?
#20152
marc replied the topic: Conquest problem
Does your strut have a skeg? (fin under strut)
www.modelgasboats.com
Home of the WARPATH Riggers
#20153
SHOOTING replied the topic: Re: Conquest problem
Yes this is Speedmaster strut !!!Some poeple tell me change the prop for 3 blade or move the strut 1/4 '' right side but i d'ont know !!!
#20158
Scott replied the topic: Re: Conquest problem
Just my feelings here ... WRONG PROP !
When I had and raced my AM Conquest best handling and speedy prop was the Propshop 7016/2
As you are experiencing now SOME props when set up hub above water line ( High Surface drive ) the prop walk is excessive causing hull to handle poorly with tracking issues or blow off troubles.
Prop change ;)
#20159
The 7016/2 can fit with my wherehouse hobbies Zenoah M5 mid-mod ? i want to tell you my sullivan 16 oz is located on right side ! that is ok or not ?
#20161
A 7016/2 should be just fine with a mid mod IMO
Ideally a BAG tank ahead and under engine is best, Hard tank in sponson LEFT SIDE helps counter prop torque left side sponson lift, Right side as you are should be just fine if playing and not racing ;)
No right or wrong way ... end result in HOW WELL you set boat up trim wise playing with props, there depth and C/G balance.
#20162
Hello can you send me your email i will send pics of my gas baby ( it is only for fun not for race but i love speed :woohoo: )
#20163
Post your pictures here ;)
#20165
Yes please post some pictures. Best props on my Conquest are 6717/3 series from Brent Daily. Been racing the Conquests or over 5 years now and still as competitive as any.
#20168
