Removing ethanol from gas
Steve Seebold created the topic: Removing ethanol from gas
I remember seeing an article a few months/years ago that gave a brief discription on how to remove ethanol from gasoline.
Anyone rember that?
#20093
Steve Seebold replied the topic: Re: Removing ethanol from gas
I FOUND IT. I looked on ASK.COM and the instructions there say to put a gallon of gas in a clear container with a lid and add water. Shake vigorously, then let the container sit while the water and gas separate, then pump/pour off the gas. The water acts as a catalyst and the ethanol is mixed with the water and the two separate from the gasoline.
Easy enough, I think.
#20095
Gasgasgas replied the topic: Removing ethanol from gas
I use a small petcoke just above the water line and drain off my 100% fuel this way . I get 1gal of 87oct add 4oz of water shake let stand still over night , open petcock above water line and get to the pond with 100% gas . Been doing this now for 2 months . Works great in my fun boats .
#20145
idocdave replied the topic: Re: Removing ethanol from gas
This can help also
pure-gas.org/index.jsp?stateprov
Just click on your state and see if you have one near you
mine charges a few more cents per gal.
Dave
#20146
Time to create page: 0.122 seconds
