What is the strongest servo?
monstrosity created the topic: What is the strongest servo?
here is a question im hoping someone may know the answer to:
What is the strongest ( torque ) servo??
must be " standard size" not 1/4 scale and normal wiring not bambozzled like SANWA munted servos LOL
the best i could find was a HITEC HS-7950TH which is 29 KG @ 6Volts
FYI need for a prototype Hydro-foil concept with retractable foils
#19451
Mercury94 replied the topic: Re: What is the strongest servo?
I have been using futaba S9157 servos for my rudders on hydros and monos and have had no problems. 425oz.@6V.
#19454
The following user(s) said Thank You: monstrosity
Peter Duggan replied the topic: What is the strongest servo?
Check out the higher voltage servos (I've noticed some 11.1 volt ones on the hobby city website) that have around 40 kg of torque.
Peter
CoCr Racing Propellers
#19456
smokeater2005 replied the topic: Re: What is the strongest servo?
Savox SB-2270SG
Dimensions: 40.3x20.2x38.5mm
7.4V: 444.0 oz-in
What do you guys think the min oz-in should be for my 54" bonzisports hull build up?
I also would like to stay with a standard servo. got a 120 oz-in for the throttle
just need to figure a solid performing min oz-in for a rudder, and or for a steerable sterndrive? any input is welcome...
#19458
Harv replied the topic: Re: What is the strongest servo?
Check out the Savox servos, I get mine @ A Main Hobbies, super to deal with
Harv
#19468
woody replied the topic: Re: What is the strongest servo?
About servos: If you want extra power it's simple: Just put two in a row.
Woody (AKA Woodie)
#19475
Time to create page: 0.249 seconds
