Rcmk K30 pistons
adian_ges created the topic: Rcmk K30 pistons
I am just wondering if anyone has had any problems with the piston ring locating pin on the new K30 pistons.
I have had 4 (four) piston ring locating pins break on me in 24 hours.
When I compare it to the Zenoah piston the pin looks of a different material and is smaller. Can anyone comment on this.
Adian Gittens
Yanmar Marine Engine Dealer
Marine Diesel mechanic for 20 years
Owner of Gittens Engine sales and Services co.ltd.
#18915
Scott replied the topic: Re: Rcmk K30 pistons
Here we go again :S .... know nothing on the k30's, but ring index pins have been an issue before.
Contact your local distributor and demand FREE replacements or go too the RCMK factory direct with your issues.
#18916
Canadian Hot Rod RC Boats replied the topic: Re: Rcmk K30 pistons
sounds like a production issue .........
#18917
adian_ges replied the topic: Re: Rcmk K30 pistons
I contacted the Distributor and they offered to replace one of my damaged cylinders, That was Ok , but it does nothing for the reliability of the piston.
One pin broke as I started the engine.
Adian Gittens
#18918
Not sure about skirt length ? ( Rcmk a tad longer ) ... but the 36MM Zenoah piston may work as well.
Just tossing it out there :huh:
#18927
I have been using the Zenoah pistons before but the squish clearance was too large with the +1mm crank, using this piston increase performance drastically as you can get the correct squish without allowing exhaust pressure into the crankcase.
Adian Gittens
#18932
Mercury94 replied the topic: Re: Rcmk K30 pistons
Find it odd that you've lost four pistons. I've been watching Jim's and talking to people running K-30 engines I have not heard of this. Do you have pictures of the failures?
#18942
smokeater2005 replied the topic: Re: Rcmk K30 pistons
I two find it odd that u have had problems with 4 pistons pins. Maybe this could be another problem that isn't directly on the surface for u yet.
Maybe engine breakin
Maybe prop needs ajusting
Shaft complications
A really bad string of luck
Maybe your application is pushing engine to limit and the pin is the first weak point, maybe try to fab a pin out of a stronger material...titanium?...
#18946
Are the pistons stock ? or were the Modded before using?
#18947
Just to toss it out ????
An issue that "Can" exist breaking ring index pins can happen most typically when the exhaust port gets modified and EITHER by virtue of a flat profile port roof ... Or, a non symmetrical shape of the port.
*A flat roof causes ring snagging/clipping as ring gets slammed back into its groove from it being out slightly as it pass's over the large area of the open port.
* A port shape not symmetrical walks the ring side to side every time it pass's up and down within the port opening.
** Both these will impact the rings end gap against the index pin damaging in time both the ring and index pin.
Just an FYI ....
#18948
Time to create page: 0.315 seconds
