trouble with rcmk
gasworx created the topic: trouble with rcmk
orderd two new rh pullstarts on 10/25/2011 after the other four i have had have all died, (bad design) paid for them but rcmk have not dispached or processed my order,
i have tryed sending emails, and also posting on their forum but have still had no reply!
rcmk assured me that they were producing stonger pullstarts but there is no sign of them.
anyone else had similar problems?
#18069
mitchesx replied the topic: Re: trouble with rcmk
I had the same problem. I had two RCMK's (both have since been sold, one in the boat, the other as a spare). The first one I didnt shim correctly and it tore the nylon all to pieces. The second was spaced correctly, and the starter just died. All the parts look pristine, literally third pull, and it wouldnt engage. The first I replaced with a spare Zen starter, the second I asked for a replacement and was denied, so I used a spare zen starter again. Was told there was no problem with the RCMK pull starters; user error. I picked up a skiff this year with a stock RCMK; it has an easy start..... Thank God!
#18071
bh_trade replied the topic: Re: trouble with rcmk
I posted this on JRCBD last week . . .
Yeah, those RCMK starters suck, same thing happened to me. At the time I was going to order an EZ start from Gizmo but they were sold out. Ended up bolting on the starter from my old Zen G230 and it has worked like a champ ever since. So in the event ur having a hard time locating EZ, a standard Zen pull start works just fine.
#18072
gasworx replied the topic: Re: trouble with rcmk
the problem is its a rh engine, cant find those starters anywhere!!!!!!!! also im pissed off that its been over a week and no reply about my order, they got my money, i want my goods!!!!!!!!!
anyone know where to find a rh pullstart???????
#18077
Right hand.... Have you checked with Bruce at Gizmo Motors? www.gizmomotors.com/
#18080
MATHO replied the topic: Re: trouble with rcmk
guys, I am using the RCMK starters in each direction (lh and rh versions) with all my multi-cylinder engines and I did not have any issue with those.
2 tricks or howtodos:
1st)trick is to put a 3mm shim/washer between flywheel and starter nut because in delivered condition the gab is much too high an then the starter axis will be bended too much.
2nd) check the knot of the starter cable in the starter handle, sometimes not properly prepared by the manufacturer.
Change your package in this way and check the knot of the starter handle, then you won't get problems....
#18091
new ali starters in december!!!!!!!!! finaly had a reply. will do the shim trick and see how it goes, i think that the compretion of the engine is to big for the strength of the nylon starter parts, which compress, swells then fails to allow the starter to retract on the recoil
#18092
