solo two stroke engines ??
George abi created the topic: solo two stroke engines ??
I came across an abandoned harm monster truck with a solo two stroke engine the truck was beyond repair but the engine started after the second pull and seemed to run pretty nicely any thoughts on running engine in a mono, can I keep it air cooled, what sort of pipe would be best, any help would be greatly appreciated, sticker says
It was made in Germany
#17845
C@T replied the topic: Re: solo two stroke engines ??
Matter of fact it was manufactured in germany some time ago.
They stopped selling years ago, so it will be hard to get an spare parts.
Loocking at performance it shouls at least perform same or better than a stock Zenoah.
Engine has 23cc, so you coul use any pipe you would attatch to an Zenoah.
I do not see why it should not be used with the air cooling,even in a boat.
#17852
George abi replied the topic: Re: solo two stroke engines ??
Hi c@t thanks for the info very much appreciated have you used solo engines before?
#17859
