Gm 230 pum clutch
Moore4x4 created the topic: Gm 230 pum clutch
Looking to put a clutch on mine. What kind will fit and will I have to move the motor forward?? Oh I'm new to boating to so I have no idea about this stuff thanks.
#17708
Scott replied the topic: Re: Gm 230 pum clutch
Being clutch has greater diameter than a cable collet, most uses where a "non" clutched engine was installed, a higher engine placement above hulls bottom required for clearance. If fitting the clutch on engine clears hull ? ... use a shorter drive cable and just run it !
#17720
Canadian Hot Rod RC Boats replied the topic: Re: Gm 230 pum clutch
I believe your boat has never hit water yet - why not try it first and see if u need a clutch - most will slow down pretty good just at idle.
Why do u want to add a clutch?
- many out there and many diff types
Try it ............ maybe you will like it without clutch
#17728
Moore4x4 replied the topic: Gm 230 pum clutch
Well I got the boat in the water today runs good. Took it slow just to see how it run. I love the boat and power.
#17786
cool show us a few pics or video
glad u splashed it
#17794
Time to create page: 0.170 seconds
