Scott replied the topic: Re: CRANKSHAFT?
Crank welding was tried a few years ago with only limited success.
The crank pin is Case hardened high carbon steel, the crank half's mild steel forgings.
When TIG welded the two parts get there natural molecular structure altered causing them to become unevenly stressed at the area around the weld site.
While the actual weld will help to keep the crank in alignment, it actually weakens the integrity of the parts.
18 years 8 months ago
#1662
