thoughts on run
dazzido created the topic: thoughts on run
Hi everyone had boat out today rather choppy water but needed to test strut altered to slight negative,personally think doing this has generated more forward thrust instead of having a huge rooster tail.Short clip of todays run so please comment,thanks Darren
#16047
Woodie replied the topic: Re: thoughts on run
Hi Dazzido.
Taken the choppy water, I think your boat is doing fine. But I also think you need a much larger pawn to have it perform to its best.
Craig Dickson replied the topic: Re: thoughts on run
Hi Daz
In my opinion that clip (compared with the previous clips)shows your boat running the best yet.
Well done.
Craig
#16051
Scott replied the topic: Re: thoughts on run
Boy is that tight quarters !!
Looks good, tho the hopping once in proper trim should be gone as well.
#16052
Time to create page: 0.155 seconds
