Propeller best polished or left satin/mat?
Craig Dickson created the topic: Propeller best polished or left satin/mat?
Hi folks
From what I’ve read it seems that there is some debate as to whether it is best to finely polish the blades of a prop or leave them with a satin finish.
Do you find that it makes any noticeable difference to overall performance?
Your opinions will be much appreciated.
Craig
B)
#15625
INEEDSPOTS replied the topic: Re: Propeller best polished or left satin/mat?
its said that a shiney smooth as glass surface is faster, but a satin finish has better grip. Ive personally seen no difference.. polished is ok if you want to spend the hours and hours of work to keep em shiney.
#15626
Mercury94 replied the topic: Re: Propeller best polished or left satin/mat?
I have two Octura 460/3 blade round ear cutback props I did for my mono. One polished and the other finished with rough Scothchbrite and I can't see any performance difference.
#15627
Scott replied the topic: Re: Propeller best polished or left satin/mat?
Done my own props for years having the final finish 600 grit wet/dry rubbed.
Polish is bling and in a LOT OF CASES worse off because the buffing wheel rounds corners of working edges and props efficiency drops.
JMO ...
#15628
Craig Dickson replied the topic: Re: Propeller best polished or left satin/mat?
Thanks for your interesting comments (no noticeable performance gains expressed so far with polished props).
I must confess I have prior to trying a new prop this weekend just polished its blades as the final process (I do like the bling). I applied the polishing compound by hand using a cotton cloth as I wanted to minimise rounding over the leading edges.
It took me a lot of time however doing it without the aid of a machine.
Craig
#15629
marc replied the topic: Re: Propeller best polished or left satin/mat?
Scott wrote:
I agree... I don't think it makes them any better... and if anything, in theory , like Scott says, can mess up a lot of the important edges that should be sharply squared and not rounded. In any case, I don't think we could ever notice the difference unless it was terribly messed up! :laugh: One solution if you want to to do everything theoretically right, polish first and square off trailing edge etc afterward.
#15631
Canadian Hot Rod RC Boats replied the topic: Re: Propeller best polished or left satin/mat?
I have all mine polished -- the one's I have bought from Bob English (several now) all came polished - from Dave Marles all came polished - the one`s from VooDoo all came polished
I think a lot of it is how u polish and like most here said
u have tried both and no diff - and that u `could`round the edges - both statements say the same no actual diff.
Same reason I paint with Automotive paint and some paint with spray bombs (u will never get the same finish from a spray can) - to me they just don`t look finished without polished
And if there is no diff ........... then I`ll stick to polishing
#15632
315neil1007 replied the topic: Re: Propeller best polished or left satin/mat?
What about anodized finish. We see more & more of that on rudders mostly. I've been told not to sand anodized finish. Yes /no
#15633
You can only anodize aluminum. I would not use aluminum props on powerfull gas models.
#15635
Hi folks
Thank you very much for taking time out to comment. Some good advice has been given here as well as your shared experience.
I am massively impressed with the prop collection from Canadian Hot Rod and I love the neat storage system. I’m pleased that I am not the only one who loves the shiny props!
Neil’s comment on the anodized finish was interesting. My limited understanding of an anodized finish is that it is primarily a surface treatment applied to aluminium alloys. I can understand why you aren’t supposed to sand the surface because it removes the tough surface coating. Whether or not one could apply a quality anodized finish DIY style is outside of my experience.
Craig
#15636
Time to create page: 0.554 seconds
