Sponson Depth?
Ozpulse created the topic: Sponson Depth?
What would be a good/average sponson depth from the bottom of the hydro hull?
Dont want to stuff this one up! :blink:
Thank guys,
Chad.
#13168
Moofy07 replied the topic: Re:Sponson Depth?
Hi Oz,
I presume you are talking about the Starwars (I guess that is what it is for) hydro? I usually run mine (depending on overall lenght)approximatly 18-22-25mm depth. For an approx 1 metre (39.5inches) I use 18-22mm (around 3/4 inch) for longer approx 22-25mm (just under an inch).
These are the measurements I usually build to for an outrigger, others vary slightly. BUT for your Starwars design I cannot tell how it will work out. You may have to even go deeper but it has every chance of reaching for the stars. I would wait for a few more ideas before going ahead. Unless you have plenty of time and foam.
Hope this helps.
Moofy
#13169
isuzudude replied the topic: Re:Sponson Depth?
Hey Oz.. send a pm lrx, the guy that makes those new bad a#$ hydro hulls. He could problably help ya out.
#13170
Hi Oz,
I presume you are asking about FRONT sponsons, not the small ones most run on the rear.
Also this is one of a million problems that arise when building a completly new design. Some of the regular things work, most don't, so you cannot always go by rule of thumb.
Moofy
#13171
Ozpulse replied the topic: Re:Sponson Depth?
Oh I have plenty of time!
And now I have plenty of foam too! ;)
Those measurements you gave were for the front yeah?
Cheers Moofy!
I will give him a pm too! B)
Thanks Doug!
#13172
Hey Oz
Yeah, the FRONT.
Moofy
#13174
Time to create page: 0.152 seconds
