twisted cat hull
ian69 created the topic: twisted cat hull
hello every one i just got a 2nd hand insane gen 1 cat and put it on some glass and has a slight twist in it .about 2mm how huch will this affect the handerling .im repairing the bottom of the hull with qcell just a couple off little holes and wanted to no what you think. thanks ian
#12012
martno1fan replied the topic: Re:twisted cat hull
Weight it down so it sits flat and leave it in the sun for a day and it might straighten out.
Mart
#12039
marc replied the topic: Re:twisted cat hull
2 mm is enough to affect performance. I would make sure the bottom is as straight as possible.
#12040
Dicko replied the topic: Re:twisted cat hull
Looking from the back of the boat with the stern held flat on the bench, the right hand sponson on some cats will lift up. This is to stop the cat digging in and hooking in turns, if the left sponson is raised you may have an issue. I've seen a cat with 10mm or more twist & it handles really well & was a very fast contender in heat races.
#12064
ian69 replied the topic: Re:twisted cat hull
ive leveled it up with qcell and i will run it .i can take the qcell out and run it with the twist i just got to get out and run it thanks four the replys ill let you know how it goes
#12087
well i got to run the cat today sorry its been awile had a bit on lately. it seem to run pretty good.will gps it next run .now it ran nice and straight and tured really good .one thing i picked up was when turning there was no water going in the eng .its got a china rudder on it so thinking i will put a seedmaster rudder on it maybe a tapered blade .also the the right sponson will drag a little bit at lower speed like its got a little bit of prop torque i run a seaducer prop its a x470-2 the strut was set at 1/4 inch above the sponsons .will do some more testing with gps . thanks ian
#13165
oldracer replied the topic: Re:twisted cat hull
did you set your strut 3/16 to the right when installing,i know the the boat will go to right if you don't.
#13242
Ozpulse replied the topic: Re: twisted cat hull
Have you checked the balance left to right?
The setup may just be heavier on that side! :dry:
My Quaka motor has heaps of torque to the right especially when taking off, so much so that if I throw a bit of a turn to head out it actually lifts the left side right out of the water and runs on the right sponson! A quick flick of left rudder and it drops that side back down! :laugh:
#13244
Moofy07 replied the topic: Re: twisted cat hull
Hey Oz,
Have you noticed that it is mainly Ozzies using the site at the moment. Except a Texan (Isuzudude) and a Danish guy (Woodie) I hope they are looking after our Princess Mary. She seems to be helping with the population growth over there. Good on her. If you see this Woodie it is a compliment, ok.
Moofy
#13256
isuzudude replied the topic: Re: twisted cat hull
My excuse is, and maybe y'alls too, we are just into more than the "normal" people B) I love comin on and chattin with y'all. I've come across some great ideas on here... and plus I like pickin at Woodie :silly: hahaha B) My biggest problem is, when I get into something, I jump in with both feet. Sometimes that's a good thing, sometimes not too good. But ya never know unless ya jump in. B)
#13257
Time to create page: 0.449 seconds
