Prop Recommendation
mitchesx created the topic: Prop Recommendation
Can anyone give me some ideas on whether I have a good starting prop for a Wood Whiplash Gen 1? I have a 2716/2 (stock), and I will be running a stock RCMK s254 EVO. Thanks!!
#11543
Scott replied the topic: Re:Prop Recommendation
That is Brians recommended prop.
6518/3 is another good one.
If hull splashes a lot of water from the front recovery pad areas while running ?
** let me know, have a cure :P
#11544
mitchesx replied the topic: Re:Prop Recommendation
Thanks, Scott! If I get the splashing from the pads, I'll let you know! Just a little more to do, and I can get 'er wet! :woohoo: ;) ;) I have a 6518/3 on my T-boat - I'll try it too.
#11548
Gone On Racing replied the topic: Re:Prop Recommendation
Hey dude,,,what is the fix???? :woohoo:
#11584
Cure is attaching inside edge secondary ride pads of @ 3/4" width and 3/16" thick. *By raising hull 3/16" on the secondaries the recovery pads are taking away from the water surface further so the boats splashing and bow sticking is far less. Hull also run faster due to less wetted surface area.
* Blend in the leading edge up against the pads trailing edge.
Make sure secondaries are straight and true with inside edges of sponsons and VERY flat and sharp cornered.
#11590
Scott wrote:
Thanks Scott..Hope to have it's maiden voyage here in the next week.. :woohoo:
#11591
