RE: stinger drive
helsing created the topic: stinger drive
hi guys i was just wondering whether you can get a longer stinger drive than 105mm and if its a yes where from ?? i have hunted everywhere, i need one about 125mm. i hope someone can point me in the right direction
many thanks
#11270
TopSecretBoats replied the topic: RE: stinger drive
This stinger drive will put the leading edge of the prop at 118MM to 123MM from back of boat.
topsecretboats.com/inc/sdetail/556
Gas Boats are nothing but fun!
#11271
Scott replied the topic: RE: stinger drive
I use one of the stinger drives and did a slight redesign of the "Cartridge" bearing / output housing so it would better index a fixed length held by a O.D. web when assembled while also better taking direct thrust loads without slipping further inward when needing the longer length. Some drives need housing bottomed out within drive if using solder on flex ferrels. Compression collets on welded stub shaft/cable assemblies don't thrust on end of drive housing. So what exact custom fix you need is a easily adapted too with some guidance.
* Point I am attempting to make is, If you simply build an output housing with the desired length and adapt it to whom evers drive ? ... you can get what ever prop positioning you want :good:
Note: OEM housing on bottom, custom on top.
#11275
Dicko replied the topic: RE: stinger drive
RCMK make an adjustable strut.
www.rcmk.com/
Their stut ST and alien struts are adjustable, you will need to run an RCMK flex & dog though, they use an 8mm prop shaft (inside stinger) with a screw on drive dog that steps down to a 1/4" prop shaft at the drive dog. I have one & they work well.
#11276
Steve Seebold replied the topic: RE: stinger drive
I make a outdrive that could easily be made the length you want.
#11279
