sendec tach question
50 stowe created the topic: sendec tach question
Does anybody have a fix for a sendec tach that does not like water. My old tach loved the water. lol After the first dunk of the day it does not work till it dries out. Not to helpful when i am testing setups.
#10278
Moofy07 replied the topic: RE: sendec tach question
I have found those small plastic containers with snap on lids seem to work ok. But you must seal with silicon where the cable (lead) goes through the box.
Hope this helps.
#10291
50 stowe replied the topic: RE: sendec tach question
Thanks for the idea moofy07. Did i just get one that is not sealed good, because my old one was in the water alot and keep on ticking, or was i just lucky with the old one. I think i am going to try and use rtv around the base and the tach lead signal hole first.
#10319
marc replied the topic: RE: sendec tach question
I thought they were supposed to be water proof??? Never had problems with mine.
#10329
Tar18 replied the topic: RE: sendec tach question
My tach has also been in water and no problems. So far.!!
Regards
Tar
#10402
Harv replied the topic: RE: sendec tach question
you could also use liquid electical tape applied sparingly Harv.
#10403
Cam-man replied the topic: RE: sendec tach question
You might want to give Sendec a call as mine do not have a problem at all getting wet
#10419
rapture replied the topic: RE: sendec tach question
I to have a problem like that with one. It works fine but after couple of run it will not read nothing.But the next weekend i go out same thing all over..
#10430
Time to create page: 0.301 seconds
