Scott replied the topic: RE: Crankcase heat ?
Because our purpose built engines are water cooled and unregulated too flow and temp of water flowing threw system it varies quite a bit. Now ideally the temp between stock or modified in a cooling system being regulated by end user is one in the same, water boils at 212* F at sea level.
Our engines RUN BEST with at minimum 170* and still run great mid 200's ! so long as carb mix is correct. You want a water cooled engine while operating WOT under load to stay 180/190*, do that your in the sweet spot.
I will note a lot of RC boaters never get engine hot enough and run a lot cooler than this. It can work fine doing so but at the expense of a bit of HP.
JMO,
Scott
16 years 5 months ago
#10261
