First Build - Easy Vee Zipp Kits
charre2 replied the topic: Re:First Build - Easy Vee Zipp Kits
Pictures would be awesome. Also does anyone have any experience with the XP-2P drive from warehouse hobbies? This is supposed to be a budget build and I am a bit stuck between the zip kits hardware package and the XP-2P drive package.
Also Pictures of the engine so far...
#12960
Mercury94 replied the topic: Re:First Build - Easy Vee Zipp Kits
I used the Zipp hardware on my EV and it works good. I did change out the needle bearings in the drive with oil-lite type. The needle bearings are harder to maintain because they rust. Rust is death to needle bearings.
#12967
I don't doubt zip hardware its just that Id rather buy the enforcer XP-2P because Its a more complete kit at a much less expensive price. Also I want to use this for wave running so I prefer a center rudder. However, I don't want to buy the XP-2P if its just not durable.
#12968
Makes sense. I don't have any experiance with the XP-ZP. I would put a small amount of glass on the inside joint where the bottom meets the transom. I have used mine for racing all summer long and it seperated a little in that area. Racing puts more stress on stuff but I would still do it for sport boating.
#12969
You can get an upgrade for it where the rudder plates are carbon fiber. On the website they claim that carbon fiber is stronger than aluminum, however I think that carbon fiber is just more flexible. I'm trying to weigh the options but the XP-2P drive with the carbon fiber plates is a very attractive choice.
#12970
Just an update:
The hull has come in, but I'm waiting for epoxy and glue from tower hobbies. Check back in a week for some awesome build picks. The hull looks awesome even though its still in the box. I also have mounting hardware on the way for the engine and Ive found a great budget Rx/Tx system called the FS-G2 system. Its a 2.4gh system for under 30 dollars that has been getting awesome reviews.
#12981
ridgerunner replied the topic: Re:First Build - Easy Vee Zipp Kits
Your engine looks like one of the newer 26cc Homelites that have a slanted crankcase and you'll have to rig up mounts for that area.The older Homelites have a vertical crankcase which use mounts simular to these. Click on the writing under the pic of the engine and it will show pics of the mounts. I couldn't get a direct link to work. www.majorsmackdown.com/homelite.html
#13016
nope its vertical and it says 25cc right on the case.
#13017
