INSANE GENERATION 3 J&G POWERED CAT
gforce replied the topic: Re:INSANE GENERATION 3 J&G POWERED CAT
Understood. I'm pretty sure that boat is being built for pure speed. I doubt that it will ever see a racing oval. Any Idea what it can do in full SAW trim?
#6162
INEEDSPOTS replied the topic: Re:INSANE GENERATION 3 J&G POWERED CAT
gforce wrote:
Well i went 70mph with my Insane Gen2.. and Jon Cinquegrani set the NAMBA G1 SAW record with his Gen2 at 76mph..
so if you believe all the hype about the Gen3 being 4mph faster then the Gen2's.... a Gen3 should run between 74-80mph.
#6165
INEEDSPOTS wrote:
In your opinion how does the insane compair to the Stryker cat?
#6172
They both have their upsides and downsides. The styker is very easy to setup, very forgiving on setup and is not picky about props to run good (especially for heat racing). The Insane is easy to setup (for me at least, ive setup 3 of them), but can be a bit picky about props and tends to like the "exotic" props moreso then the standard octura props (again, for heat racing).
One thing i myself like about the Insane GEN2 (not the gen3) over the Stryker...is the ability to get the CG very low in the boat because of the dropped pod, which the stryker does not have.
#6173
INEEDSPOTS wrote:
I dont think there is a dropped pod in the gen 3. If there is I didnt notice it. I think I remember that the gen2 has kind of like a tri hull like the full size mirage jaguar or an STV. The gen three does have a moulded in stuffing box. I am not sure about the radio box being integrated into the deck and they dont supply a cover for the acess hole for the transom. The tunnel is also much smaller in the gen3. The boat is beautiful and very straight and square.
#6174
CPMODS replied the topic: Re:INSANE GENERATION 3 J&G POWERED CAT
ok guys,after a short brake in the beast ran!!!!!...lol,it had a modded grimracer prop 2 blade 65x100.the boat was set for oval racing and after a few adjustments it ran 66.2 mph on a windy day,this runs like is on tracks,i'm very pleased,i eill modified the j&g and set it fot saw and i will try to post video of it.here are some pics,i hope you guys like them
#6271
more
#6272
mo
#6273
the guy with the hat is me!!other one is andres the owner of a&e.now you know me...lol
#6274
marc replied the topic: Re:INSANE GENERATION 3 J&G POWERED CAT
Cool... looking forward to seeing the video too!
#6279
