Warehouse hobbies Team Pro
tootalltechie replied the topic: Warehouse hobbies Team Pro
You know it's a fuel tanker :) or maybe a "Big Heavy"
#24584
marc replied the topic: Warehouse hobbies Team Pro
Awesome news!
#24585
The following user(s) said Thank You: tootalltechie
Rysquedases replied the topic: Warehouse hobbies Team Pro
That is awsome ! Always nice to here good news especially when it's about negative cancer results. Get well soon.
#24588
tootalltechie replied the topic: Re:Warehouse hobbies Team Pro
New Gizzmomotors 30.5 cc billet installed. Think I have worked out all the "new engine headaches". She started on the first pull for the first time after doing a complete rebuild.
#25625
I replaced the rails with 1/4" ply, replaced radio box with one just to hold receiver & battery, new speedmaster 6" rudder centered on the right engine rail, hi tec digital waterproof servos, 16 Oz hard tank, tachometer with mount. I think I shaved a couple pounds off stock ready to run trim. The engine is a gizzmomotors 30.5 cc billet pro mod CNC Zenoah. The carb is a stock WT-257. The pipe is a 1" DP hot pipe. It started out being a 4 bearing setup but a leaking bearing seal changed that to a 2 bearing setup. I'm using a TK lite rotor & primary coil with a Zenoah grey secondary coil (the TK secondary coil was in the way of the starter rope). I'm running a single square flex into a whh spdIII drive.
#25626
tootalltechie replied the topic: Re:Re:Warehouse hobbies Team Pro
Video of first day out
#25627
