66'' 1.7m carbon kevlar SV43
jason phillips created the topic: 66'' 1.7m carbon kevlar SV43
hi all,
this boat is for sale on here, but have been plodding on as and when i can.
thought id post progress and see what you think
Jason
#21178
jason phillips replied the topic: 66'' 1.7m carbon kevlar SV43
t
he hull is a full Carbon / Kevlar construction with a Kevlar top to allow for radio signal.
#21179
1st job was to clean up the hull, unfortunately there was a rough join at the seem which took allot of sanding filling and sanding. also filled some imperfections on other parts too. then set to mark and drill off the windscreen ready for rivets to help give that real look
#21180
next job was to add some vents, for visuals and to allow some heat build up out as required. these will eventually have under trays with water drains on to help keep the water out.
#21181
high build primer on the local area to start to blend, this will be followed by an all over shot to blend the whole boat, 3rd shot will be standard primer
#21182
marked up the drive fixing holes, the trim tab and the exhaust-water dump mountings (the blue was inbetween coats that i was not hap[y with, so re did it)
#21183
Drives and mock exhausts dry fitted.....
#21184
hi!
made up the water pick up from s/steel, polished and welded....
#21197
mock up of extended rudder mount
#21235
finished off the rudder stand off bracket
#21426
Time to create page: 0.781 seconds
