52 inch mono build I need help
itri45 replied the topic: Re: 52 inch mono build I need help
I have now decided to build the 72 inch mono instead of my homemade plans for the 52 inch mono as i did not think they were as good as i thought they would be. :cheer: B) :cheer: :cheer:
still using the same power plant.
im thinking im going to build a plywood rudder to start with.
#16129
Ozpulse replied the topic: Re: 52 inch mono build I need help
No go on the 52" :(
Jumping up to that size boat means it will no longer fit into a 'normal' car for transport to the pond. :huh:
A plywood rudder?? I think unless you were laminating the strips yourself alternating with some CF or similar it wont hold up to the job, although it would look nice. B)
#16130
marc replied the topic: Re: 52 inch mono build I need help
I will take a look in my stuff, I should have a strut and rudder I could send you. Build the boat! :)
#16134
Dear marc i am going to build the 72 inch as i have a large, i mean very large pond in my backyard that i can drive the boat in. my dad also has a truck i can use to transport the boat. therefore i am going to build the 72 inch.
if you cold sned me a strut and rudder assembly to could you also send me a ferrule and a shaft for a prather 280 prop? that would be awesome B) B) B)
#16135
itri45 wrote:
Can't help you with the shaft and ferule...you can get that pretty cheap from Aeromarine or places like that. I just happen to have a strut and rudder sitting here at the shop, that I can send you if you want it.
#16136
marc wrote:
How much would it cost for u to send it to me
#16137
Just send me your address (PM me) and I'll get the rudder and strut out to you this week sometime.
#16138
At no cost to me! that would be awesome! :) :) :)
what size prop do you reccomend i use for the boat? and also what shaft should i use
I will pm you later :)
#16141
I have actually decided to build my own rudder and purchase a strut offline :)
sorry.
#16146
hold the assembly for a few days. i may want it. it must fit a 1/4inch prop shaft though.
#16149
