what is the best mix oil with fule for the zenoah
lohring replied the topic: Re: what is the best mix oil with fule for the zenoah
8 oz per US gallon is about 16:1. We have tested 10:1 with some power loss in a Quickdraw at high rpm. 13:1 still seems ok, but we normally run 16:1 for heat racing and straight line work. When we tested alcohol based fuel, we ran boat fuel that was 18% oil. That would be 5.5:1, and that is considered normal for glow engines. I think the issue is fairly complicated, but mostly you richen up the mixture a little to allow the same amount of fuel in.
#506
WAKEMAKER replied the topic: Re: what is the best mix oil with fule for the zenoah
:)HI Lohring
Thanks again. I will try the 16:1 mix. I am the agent in SA for CY engines (SIKK). So I will try the mix with this engine as well as a Zenoah. We have seen that the stock CY has more power than a stock Zenoah, so it will be very interesting to see the power difference from the 40:1 mixes that we used.
I mentioned the fuel ratios to other "PROS" at the dam, and they didn't think much of it. I'm excited to see the outcome.
G.
#507
You won't see a huge difference in heat racing. It shows up if you test carefully against a radar gun or GPS, and it makes a difference in straight line speed runs. Because the power required increases as the cube of speed, big changes in power only result in small changes in speed.
#508
Has anyone tried the MORGAN oils, 2-stroke carting oil in the boat engines? The same oil can be used in Nitro engines. We supplied some to some top onroad races here and they claim a 20 deg C drop in running temp!
Morgan has the CP-07? friction modifier additive which they make certain claims about.
I want to try it in my CY26 but I hope someone else has some experience with it compared to other oil like MOTUL 800?
It is the GOLD/with castor blend....
#509
wac replied the topic: Re: what is the best mix oil with fule for the zenoah
I got a Dyno together and have been dyno testing motors for a couple of months now with some good resaults . noticing any small change done to the motor transfered to the dyno graph . I personally run 40:1 oil mixture with a special proto type oil . The motor is one of the fastest Zenoah's in the club and has run for over a season with now breakages and only running Wear. The If you want to do proper testing put it on the Dyno. My Hydro ran at 114.8km/h at 1500meters altitude running a 40:1 ratio . I am not saying any body is wrong but this ratio works for me . maybe the oil is Good .One of the fastest boats in South Africa Running A ZEN.
#510
