New carb, new case new pipe. Won't run?
ottie44 created the topic: New carb, new case new pipe. Won't run?
After a few years away thought it was time to get back into the hobby. Ordered the RCMK four bearing case a new hot pipe and the 1018 carburetor . Every thing went together without to much of a problem. I have blue spark, new fuel and compression. Can't get the G26 to run or even fire with the assist of a little fuel primed into the cylinder? Tried changing plugs and grey coil but still not even a back fire!
#24249
Bob DeCortin replied the topic: New carb, new case new pipe. Won't run?
Check to see if the flywheel is lined up correctly.
#24251
ottie44 replied the topic: New carb, new case new pipe. Won't run?
If I can remember correctly there is only one key way slot in both the fly wheel and crankshaft. My first thought echoes yours in the timing is off or I don't have the red coil and mag gapped properly.
#24255
#24256
noworknguy replied the topic: New carb, new case new pipe. Won't run?
You have fuel, air and spark It will fire. Check to see if the carb. is opened a little , it might be closed and it won't run .. Put your finger over the carb. and pull the starter rope slow ,if your finger gets wet with fuel great. Good luck.
#24257
Hot Rods replied the topic: New carb, new case new pipe. Won't run?
It's probably a 1048 ( not 1018 ) carb, and make sure your needles are set properly. When hand choking, it's easy to over-do it and flood the motor.
#24268
Rysquedases replied the topic: New carb, new case new pipe. Won't run?
Did you purchase a rcmk right hand case or flywheel ?
#24270
lohring replied the topic: New carb, new case new pipe. Won't run?
Be sure there aren't any air leaks in the crankcase. We once found an engine (not RCMK or other well known brand) with the casting like the picture below.
#24272
Gulf Coast replied the topic: New carb, new case new pipe. Won't run?
Try. Take off your fuel lines, Then you know there is no fuel going to the engine. I Blow some air into the intake. While pulling on the starter. To clear anything left over in the crankcase. Test your spark again. Now you should have a dry motor with a good spark. Spray a > Very< small bit of carb cleaner in the intake. Throttle wide open see if it fires off. If it does, fuel probs. if not>>>>>>:(
#24274
Nic replied the topic: New carb, new case new pipe. Won't run?
Make sure there is not some thing in the exhaust pipe may be a paper plug or some tape over the exhaust port that you might not removed ...
#24292
Time to create page: 0.153 seconds
