warehouse hobbies 46" vee loosing power after 5 laps
tootalltechie created the topic: warehouse hobbies 46" vee loosing power after 5 laps
my deep vee is loosing power after 5 laps at full throttle. it has wet tuned exhaust, M5 zenoah, wt-644 carb, temp is 178*, fuel 30 to1, prop 2716(2) 15, double square drive no clutch.
for testing would it be ok to remove coolant hose off wet pipe?
#21621
baumer65 replied the topic: warehouse hobbies 46" vee loosing power after 5 laps
as long as you have water to the block and exhaust flange ,test away.
could be the 30 to 1 ratio?? i mix 1-1/2 oz to every 16 oz = about a 10 to 1.
maybe not getting lubed up enough and the oil helps dissipate the heat.
30 to 1 to high.
#21624
tootalltechie replied the topic: warehouse hobbies 46" vee loosing power after 5 laps
Trying to figure out why I lose power after reaching temp. With no changes to carb, fuel, not leaning out (I think), shaft has fresh lube before run, fuel filter clear, tank near full, water cooling working. Took video with a AC Blast Cat (Elwin's) and keeping up then I slow down.
#21625
I try that on next tank of gas, 30 to 1 is what I have been using from start motor should be broken in bby now hahaha
thanks
#21626
Hugh replied the topic: warehouse hobbies 46" vee loosing power after 5 laps
Seems the easy solution based on what u said is to meter the cooling with various I'd brass tubing or nipples simply run cooler and verify the actual temp. It's advisable to know the numbers - all of them when possible and log as u test to remember exactly,wat u did and wat the effect was.
#21627
is 178 degree too hot? water temp is mid 50's. Need bigger water cooling tubes and fittings? Oh yes water into cool cap at bottom out at top. Insulator on plug light brown.
#21628
can you supply pictures of your set up ,might help.thanx dave
#21629
Based on your post it may be for your setup don't know.My advice came out backwards :sick: I meant cool it more with additional pickups then meter it back if need be.Just a thought,not the gospel! Having the metering option is best even if it is not the issue.
#21630
temp is not bad can you touch cap for a sec and not burn fingers??if not to hot, how are yours lines running and are they ok. also did boat always do this or just started?? the heat we've had with humidity doesn't help.
#21631
wheres my photos? arrr
it started about a month ago, checked all cooling lines and pump
can't seem to upload photos, and no reason given
temp here yesterday was high 60's, 19*C
it was fine before I removed my clutch...mmm
#21632
