Rcmk s-520 exhaust Rotate situation and photos
smokeater2005 replied the topic: Re: Rcmk s-520 exhaust Rotate situation and photos
maybe a 90 degree on the front and a wrap to center on the back, then use a 1" tube to line it all up...
engine...
your tuned pipes...
this would be kinda like an "H" pipe like they use on v8's... just a thought...
the only real work involved would be the "H" pipe construction, u need someone with a laser welder...
#19796
you also might be able to get away with two elbows and two t-pipes....
eblow in from 90 front cylinder, then t-pipe for exhaust, then t-pipe from wrap to center "rear cylinder" then another elbow to the secound tuned pipe.
this would be the same design but the elbows would decrease the turbulance a bit...
#19797
Time to create page: 0.878 seconds
