Scott replied the topic: Re: Engine advice please
Issue will be if case O.D. is of a normal bearing OD diameter, Width equal to a known bearing of that diameter, ID with above dimensions allowing fitment.
* Lastly if crankshaft has a straight diameter from OEM bearing out to where a second bearing would reside ? ( Zenoah cranks drop @ .0015" in diameter on mag side )
14 years 5 months ago
#18075
