Prop Size for Easy Vee
quicksilver78 replied the topic: Re:Prop Size for Easy Vee
the dubro 16oz tanks works perfect if you do it as in the manual i also did a quick fill adaptor mounted closer to the transom your gonna love the easy vee lots of fun :drinks:
#7502
Rcer replied the topic: Re:Prop Size for Easy Vee
In the past I had a a easy vee also. As far as props mine ran very well on an Octura X472 and the X572.
The 472 will give you a bit more Rpms, the 572 has more pitch so it will knock a few rpms off but it is the same dia prop as the 472.
Thier are better props but these are good starter props for you that WILL work.
Rcer
#7507
Time to create page: 0.323 seconds
