Rudder servo is changing its center position
Alexia replied the topic: Re:Rudder servo is changing its center position
2.4gigahertz.com/features/receiver-tips.html
I notice you said you put the receiver in a balloon. Futaba states not to cover the receiver as it does not like to get hot. I had a binding issue one race-day due to too much sun light. Had to rebind receiver while clock was ticking down for the start.
What Hitec servo is it. I had a 805MG that use to go over centre every time I come out the corner. Had to keep on giving steering input down the strait. Other boaters use to mock me that I was a bit tipsy.
Cobus
#7011
Procat replied the topic: Re:Rudder servo is changing its center position
My servo is now a HS-755HB Hitec 1/4 scale running on 6 Volts
#7012
Steve - I'm use a mount from warehouse hobbies which lets that 105 degree pipe sit right there, Your right thats alot of heat and
like Freezer said I will cut a plug in the cover to open between runs
I didn't get a chance to try the extra receiver today
#7013
Ed you were right - I made a linkage using carbon fiber rod with 6/32 threaded rod running allmost all the way through it, tapped out some heavy duty 4-40 linkage ends - no more binding ! but sure enough the threaded rod was slipping inside the carbon fiber, The Zap gave way to excessive cornering, Drove me crazy, but all better
Thanks again
#7326
marc replied the topic: Re:Rudder servo is changing its center position
Great to hear you found the culprit. Great tip Ed! :drinks:
#7328
Time to create page: 0.179 seconds
