Which brand failsafe????
marc replied the topic: Re:Which brand failsafe????
Not to take away from anyone, but just for the record, the MHZ unit, although expensive, also covers interference and/or loss of transmitter signal. This is today's equivalent to the old Shark Racing failsafes. As far as I know, no other unit covers all these bases. The last units Shark Racing had manufactured actually monitored the servo they were connected to, in case of servo failure. To my knowledge nobody had pursued this...it's too bad, the units worked very well. In my opinion, the best overall protection available at this point is the MHZ unit. If the boat starts acting funny on you, you can switch off your transmitter and kill then engine. If memory serves me correctly you can also switch your radio's 3rd channel to kill the engine. Andre did a review on the Isam unit a while back, which is actually the same one MHZ sells. Expensive, but works great! Also like the fact that it's 100% water proof and the relay section is separated from the electronics unit which goes in the radio box.
For economical solutions, the NC relay most are selling do protect ok against power problems. Coupled to a PCM radio with built in failsafe they cover most bases efficiently. JMHO. :)
Here is a link to the Isam / MHZ failsafe article.
www.modelgasboats.com/Magazine...by_Isamtec.html
#3204
skyray replied the topic: Re:Which brand failsafe????
Let me check to be sure what voltage I am using? I will get back to you as I would be interested in one of your units!Do you have them already made up or just build to order?? Ron
#3205
INEEDSPOTS replied the topic: Re:Which brand failsafe????
I have about 3 finished right now.
#3206
binky72 replied the topic: Re:Which brand failsafe????
Marc wrote:
Not absolutly correct, this unit (which I use in my boats) from AMS do the same, www.a-m-s.ch/shopenams/tuning-...gency-stop.html . Seems that you also can get it from Daves Motor, www.davesmotors.com/store/product1670.html .
Eirik
#3503
I have never seen or tried this unit...wish I could read the specs in English... if it DOES do all the same as the MHZ unit, then I would say it is another good alternative.
#3515
