RC superchargers intercoolers and exhaust Turbos from Micro Boost
smokeater2005 created the topic: RC superchargers intercoolers and exhaust Turbos from Micro Boost
wow check it out. Sounds like rc isnt far off from going forced induction...
#18981
wichers00 replied the topic: Re: RC superchargers intercoolers and exhaust Turbos from Micro Boost
im sorry but that is no turbo charger. thats the same as a leaf blower. a turbo uses exhaust gasses to spin a shaft that spins a compressor to pull atmospheric air and compressing it to a psi and cramming it into a tight space. its more about pressure than air movement. compressed air is more dense than atmospheric so more fuel can be added to make a more powerful engine cycle.
#18982
Mercury94 replied the topic: Re: RC superchargers intercoolers and exhaust Turbos from Micro Boost
Think he was using compressed air to simulate exhaust flow. They are also for nitro motors and nitro is a pain to work with.
#18984
smokeater2005 replied the topic: Re: RC superchargers intercoolers and exhaust Turbos from Micro Boost
Yes i believe that the air is supose to simulate exhaust gasses. its only a prototype and i would thing that it will eventually need some type of self contained or circulating lubricant due to heat and bearing speeds.
i think that in theory a leaf blower is the same as a centrifical super charger which is basicaly the front half of a turbo, just belt or motor driven...
I really want to see more (dyno and operation video) cause if it works these could really increase the HP and torque of a lot of 2 cycle boat and rc cars, not to mention a lot of other little motor driven things..
#18986
"i think that in theory a leaf blower is the same as a centrifical super charger which is basicaly the front half of a turbo, just belt or motor driven..."
no its not. a leaf blower does just that blows air. a turbo takes air and pushes it into a snail form to compress the air. that intern makes a dense air and thus creates pressure. i will tell you the 2stroke marine engines we use will not pick up big gains like a 4stroke or a 2 stroke reed engine.
#18987
Canadian Hot Rod RC Boats replied the topic: Re: RC superchargers intercoolers and exhaust Turbos from Micro Boost
Looked at these a while back and spoke with him. He makes a twin set now for Zenoah - problem being is with our carbs it needs to be on other side -- in other works the systems shown are 'blow through' for our carbs need a draw through
RD
#18995
How about a real turbo ????
#18996
monstrosity replied the topic: Re: RC superchargers intercoolers and exhaust Turbos from Micro Boost
Wont work cause of the nature of how a two stroke works
the exhast side of the turbo will interfere with the exhaust waves/pulse and then if it does manage to work it will blow the fuel- air mixture straigt thru the cylinder and will be wasted..
TURBOS AND CHARGERS ONLY WORK WITH FOUR STROKE ENGINES or rotary
( or engines that have valves or some obstruction to stop blow-thru )
looks good thou for the BLING BLING factor lol
:huh:
#19006
Lots of bling bling that do zip ........ people will sell ya anything if u believe .....
I like cool but to a point ... like my old man said with my first 'rod'
" that's cool boy .. but chrome don't get ya home"
#19009
i know what you mean... hahaha but it still looks bitchin with out chrome.
#19010
Time to create page: 1.362 seconds
