stinger struts
315neil1007 replied the topic: Re: stinger struts
Steve what does the mount look like? And is it a easy out to remove the engine?
And a pic of that rudder.
#18819
Steve Seebold replied the topic: Re: stinger struts
If you use a square drive, you need to loosen one screw , slide the stinger back till square end of your flex shaft comes out of the hole and you're good to go. Only thing is, don't forget to retighten that screw when you put everything back ot you could lose a very expensive prop, and flex shaft. I know. I have one sitting at the bottom of the lake.
#18824
Time to create page: 0.939 seconds
