1:3 scale garwood speedster wooden boat build!
smokeater2005 replied the topic: Re: 1:3 scale garwood speedster wooden boat build!
both the miss america 8 and the "porsche spider" rich man runabout garwood speedster...
#19792
soon pics of the finished building jig, scaled down from the full size one that im building...
#19864
ridgerunner replied the topic: Re: 1:3 scale garwood speedster wooden boat build!
How do you go about scaling down full size plans ? I'd like to build a 1/4 scale of this boat from Glen-L plans www.boatdesigns.com/15-Cracker...t/products/207/ I'd like to find someone who has already scaled down the plans and maybe I could buy a copy of the plans from them,without having to buy the full size ones.
I have some really beautiful grained aircraft grade plywood that I've been saving for a special project.
#19870
whitefish replied the topic: Re: 1:3 scale garwood speedster wooden boat build!
Directions for how to "loft" plans can be found on several
web sites like this one:
www.diy-wood-boat.com/Lofting.html
Glen-L's Cracker has a strong curvature which forms the tumblehome
at the transom. If these curves are also compound then this design
can be very challenging to build using a single sheet of plywood. Not
saying it can't be done but having done compound plywood curves in
several applications - that one may be an advanced build.
If you would like to find a Cracker with a smaller amount of compound
curves (the compound curvature is limited to the deck and much easier
to build) then maybe consider the ZippKits V-Box. Any of the ZippKits
Crackers are a great value at their price points.
zippkits.com/~zippkits/index.p...products_id=339
Note: The link above is broken. Just look in the "Gas Boat Kits" to
find Joe's selection of Crackers.
Since this is smokeater's build thread, I will politely back out and
remind him we are looking forward to more pics.
Good luck with your project, ridgerunner.
#19879
I've heard the Zipkits crackers are cheap,easy to build and handle well,but they don't have the lines that the Glen-L design has.The closest I've found to it is the Ivan Bourdier Hot Tub crackerbox.I've had good luck bending 1/8" plywood two directions on a hull by using a steam machine and bending both ways a little at a time and putting a twist in it.Here a pic of the Hot Tub style.
#19881
Nice looking boat! There is nothing like some tumblehome for a true
classic look.
It's great to read others are practicing compound curved plywood. It
has become one of the dying arts of wood boat construction.
#19884
ridgerunner, to be honest i had to buy the plans for a full size boat and have the print shop 1/3 scale print them... if u like the design im using send me a private message and ill hook you up with my 1:1 scale pdf's...
but other than lofting there is not much to do other than buy fule scale pdf's and digitaly scale them down at print time... a bit $$$ i know...
#19911
<iframe width="420" height="315" src="
" frameborder="0" allowfullscreen>
this looks very close to the build i want to do i just wish the quality was better...
#19917
I have made a small change to my 1/3 sale printed hull frame printouts! I have changed the stringer width and depth to 1/2" wide x just a hair under 1/4" deep on the bottom and the sides. This creates less of a headache in preparing stock and cutting frame stringers to the point of less waste and differences...
#19920
Pic of small changes to uniform stringer stock...
#19928
Time to create page: 0.149 seconds
