Machining Piston to Avoid Seizures
Tech Article...by Carlo Catalanotto
Does the top diameter of my
piston need to be machined in my engine?
Well
I have been asked this question so many times that I figured it was worth some
time answering it with a write up. The simple answer is yes, the explanation
why is not quite as simple, but I will try to explain the best that I can from
some of the knowledge that I have learned over the years.
This simple modification is done on a lathe
by removing .002 to .003 from the outside diameter of the piston starting at
the
Cutting Piston on Lathe
crown of the piston to .250 below the ring land. It does not increase
horsepower it is just a simple fix to stop our engines from having the piston
seizing in the bore and destroying the piston, ring, cylinder and sometimes
more. It is commonly believed that the
reason we have seizure problems in our engines is because our cylinders were
designed as air cooled units and that the conversion to water cooled cylinders
is what has caused the problems. The theory is that the piston now expands at a
faster rate than the cylinder because of the addition of water cooling around
the cylinder keeping it cooler than it was originally designed for and without
the heat it is not expanding at a fast enough rate to keep adequate clearance
between it and the piston. This is not a bad theory, but not correct. With a
lot of recent exposure to the RC style air cooled engines, I have learned that
the air cooled style engines have more piston seizing problems in the bore than
any of our marine water cooled engines so that kind of blows that theory out of
the water so to speak, no pun intended.
The true culprit of our problem is heat
expansion on the crown area of our piston. With the addition of tuned pipes and
the recent wave of modifications to the piston to make it lighter has only made
the problem worse. The crown of the piston with heat expansion will grow more
than the rest of the piston even in stock form and there is no simple way to
cure this problem. When engine tuners remove material from the inside of the
piston area to make the piston lighter it actually makes the problem worse as
you have less aluminum to absorb and disperse the heat from the combustion
cycle. Some would believe that if it
Stock and Modified Piston
were possible to make our bore a little
larger or a smaller diameter piston then the problem would be solved. While
making the bore a little larger is not possible in our application neither of
those solutions would work correctly. If the bore was adjusted or we used a
smaller diameter piston to cure the problem then there would be too much clearance
on the piston skirt that would cause other major problems such as the piston
rocking in the bore, the ring not sealing because of the rocking and the piston
allowing seepage through the ports that it is supposed to be sealing shut. The
more research I did on this subject the more amazed I was to find out how long
this modification has been used over the years in all sorts of racing 2-stroke
engines. From the information I have gathered it has been done to high output
2-stroke racing engines for at least 35 years. While I do not believe this is
the most optimal way for a piston to be used it is the most practical and
economical way that I have found so far for our situation. Without the
manufacturer producing what would be quite an expensive tapered piston for our
relatively cheap engines, then the only way we have found so far to cure this
problem is by machining the top diameter of the piston. I hope I have helped
shed some light on this procedure and helped to save some of you from
unnecessary problems in the future.
Carlo.
CC Racing Engines
www.cc-racingengines.com
