A quick look at this powerhouse Full Mod Zenoah 260 from CC Racing Engines...
Deciding on a high performance
engine for your boat can get confusing sometimes. There are so many companies
out there offering their version of "Full Mod" Zenoah engines that
for someone in the market for the first time it can get overwhelming. Not only
are there Zenoah engines, but there are also copies or "knock-offs"
of the Zenoah. There are also purpose built engines and kits such as those
available from Quickdraw and J&G Engines.
For some people the decision is easy and boils down to customer loyalty. We see
this a lot in model boating as in any market and that is fine. If you do not
have a preferred builder however or you simply want to try something else that
brings us to what we were saying in the beginning.
Companies like CC Racing Engines however make it much easier for us to decide!
If you are truly in the market for a high performance engine for your boat,
this is one place you can be sure you will be getting what you paid for. Carlo
Catalanotto, owner of CC Racing Engines, has been in the engine business and in
racing for the most part of his life. (For a profile on CC Racing Engines click
here .) A CC Racing motor was used in the boat
CC Racing Engines have been in the winner's circle of countless races and set
many records. Their track record truly speaks for itself.
I recently purchased one of these full mod Zenoah 260 engines from CC Racing to
put in my new mono and I will say that I was very pleased with the performance.
The first time out the motor started easy and performed flawlessly. The
throttle response was good and crisp and the motor produced a lot of torque. I
tested the motor with an aluminum 2" band pipe on a 7/8" header. With
one of the new CC Racing tuned pipes that uses a 1" header, performance
should be even better! (We will be reporting back on 1" header pipes in
future issues.)
The CC Racing Full Mod Zenoah 260 features the following:
• WT257 Carburetor bored and modified
• new billet aluminum carburetor isolator block with double Teflon gaskets
• Piston modified and lightened
• Transfer ports modified
• Exhaust Port modified
• Intake Port modified
• Port timings set for intake and exhaust
• Low drag seals installed
• All bolts replaced with high grade Stainless steel bolts
• Base gasket replaced with .005" copper base gasket
Here are a few pictures of the motor. You can notice the fine work to the
carburetor throat and bell as well as to the intake port. Notice the perfect
matching of the carburetor isolator block to the engines intake port. The
inside work is equally as impressive. I prefer not show pictures of the inside
of the engines in respect to CC Racing Engines. Reputable engine builders put a
lot of time and effort in testing and development and making pictures of their
work public would simply not be right.
You will notice that the engine
is numbered on the bottom by CC Racing. If you are buying the engine used or
from a source other than CC Racing Engines directly, you can use this serial
number to check the history/authenticity of the engine with CC Racing. To be
absolutely certain you are getting what you pay for, buy your engine from a
source you trust. If buying used, I would recommend having the engine inspected
and possibly refreshed by CC Racing if you want to be certain you are getting
the most out of your engine.
Stryker Y6 - powered by CC Racing Engines Zenoah 260
One thing to keep in mind is that CC Racing Engines are in strong demand and
you should really try to plan ahead if you want one of these power plants.
Depending on the time of year there can be waiting lists so keep this in mind.
In most cases the turn-around time on an engine is 2-3 weeks so if you want
that boat of yours to get a boost of power, contact CC Racing Engines now!
Contact Information:
CC Racing Engines LLC
Carlo Catalanotto
Tel: (504) 305-5005
Website Link
Email:
