Shorten Carburetor Needles
marc created the topic: Shorten Carburetor Needles
This thread discusses the Content article: Shorten Carburetor Needles
Post questions or comments in this thread...
#6510
Scott replied the topic: Re:Shorten Carburetor Needles
Gone even further in making shorties.
Cut off ALL the straight shank down to the flange that compress's the spring, re-slit the flange with a fine tooth hack saw blade ;)
#6516
This is a VERY confined cowl area !!
#6517
marc replied the topic: Re:Shorten Carburetor Needles
That's short alright!!! Thanks for posting the pics Scott! :drinks:
#6520
marc w replied the topic: Re:Shorten Carburetor Needles
Nice, i like the simple things that makes things easier.
How about making it a philipshead instead of a single slot? Philipshead makes it easier to adjust the needles with engine is running and the carb vibrates a lot. A philipshead will hold the screwdriver easier in place.
#6664
INEEDSPOTS replied the topic: Re:Shorten Carburetor Needles
marc w wrote:
If you use fuel/water line over the needles... just make them a little longer then the needle. That helps keep the screwdriver in the groove with the tubing holding onto it.
#6665
now why didnt i think of that..... thanks spots!
#6707
Time to create page: 0.137 seconds
